Helldivers 2 Supply FRV Guide: U4N and the Value of Field Support
The M-103 Supply FRV is becoming a permanent unlock in Helldivers 2, giving players another way to keep their squads supplied during missions. Originally introduced as a limited-time campaign reward, the vehicle is expected to become available through the Ship Management terminal using Requisition Slips. For players who missed the original event, this creates another opportunity to expand their equipment options and rethink how they approach longer operations. When planning your loadout around Helldivers 2 Items, it is worth considering not only damage output but also how your squad will maintain its supplies when a firefight lasts longer than expected.
What makes the Supply FRV different from a standard combat vehicle is its focus on field support. It combines transportation with a mobile resupply point and automated defensive assistance, giving teammates more flexibility when moving between objectives. Players who regularly run missions with friends may find that this kind of support changes how they manage ammunition, Stims, and grenades. Instead of relying entirely on fixed resupply points, the squad can use the vehicle as part of its overall mission plan.
How the Permanent Unlock Works
The M-103 Supply FRV originally appeared as an early-access reward associated with the Census Thunder Campaign. Players who already earned it should retain permanent access without needing to spend additional currency. Everyone else will need to check the Ship Management terminal when the permanent unlock becomes available.
Requisition Slips are the currency expected to cover the purchase. There is no stated need for premium Super Credits or Warbond Medals, which means players can work toward the vehicle through regular gameplay. Its expected price is around 25,000 Requisition Slips, based on the cost of the M-102 Gunner FRV. However, players should confirm the actual price in-game rather than treating that estimate as final.
If you are saving for several unlocks, consider your priorities before spending everything you have earned. The Supply FRV is useful for certain squad setups, but it does not automatically take priority over every weapon, Stratagem, or other vehicle.
What the Supply FRV Brings to a Mission
The biggest advantage of the M-103 is its ability to support a squad without requiring everyone to stop fighting for long periods. Teammates can approach the rear of the vehicle to replenish ammunition, weapon magazines, Thermite grenades, and Stims. That makes positioning important, especially when the team is moving between objectives or preparing for another difficult engagement.
The vehicle also has an automatically firing Guard Dog turret. This defensive feature can provide additional coverage during supply runs or while teammates reposition. Its armored construction offers some protection against small-arms fire when stationary, although it should not be treated as indestructible.
A few practical uses stand out:
Long objective runs: Bring supplies closer to the squad instead of depending exclusively on fixed resupply locations.
Ammunition-heavy loadouts: Give teammates another option when their weapons consume ammunition quickly.
Coordinated retreats: Use the vehicle's defensive capabilities to support repositioning when the team needs to fall back.
Repeated engagements: Keep the squad better prepared between fights rather than entering every encounter with limited supplies.
The vehicle works best when teammates understand its role. It provides additional flexibility, but it cannot replace good positioning or a balanced loadout.
Choosing the Right Loadout
Before deploying, equip the Supply FRV from the Hangar section of your Stratagem loadout. Think about the other tools your squad needs and whether the vehicle complements them.
A team with strong offensive capabilities may benefit from bringing additional field support. A squad that already struggles to handle heavy enemies, however, might need to preserve its offensive options. The right choice depends on the mission, your weapons, and how your teammates prefer to fight.
It is also worth agreeing on where to position the vehicle. Parking it somewhere accessible but reasonably protected makes it easier for players to replenish supplies without exposing themselves unnecessarily. Driving straight into a dangerous area simply because the vehicle has armor can create more problems than it solves.
Making Requisition Slips Count
Requisition Slips are earned through ordinary gameplay, so players who want the Supply FRV should focus on completing available objectives and extracting successfully when possible. There is no need to rush the purchase if another unlock would improve your current build more immediately.
The most useful approach is to consider how often your squad runs out of ammunition or healing supplies. If that happens regularly, the vehicle may address a genuine weakness in your team's strategy. If your missions are usually short and your current loadout works well, saving your currency for another upgrade may make more sense.
Final Thoughts on Field Support
The M-103 Supply FRV adds another layer of squad coordination to Helldivers 2. Its combination of mobile resupply, armor, and automated defense can help teams maintain momentum, particularly when missions involve extended travel or repeated combat encounters. The important thing is to use it as part of a larger plan rather than expecting the vehicle to solve every battlefield problem. Players researching Helldivers 2 Items through U4N can also use their preferred equipment goals to decide whether this support-focused unlock fits their next set of missions.
