MLB The Show 26 May Spotlight Program Drop 5 Rewards Guide
The May Spotlight Program Drop 5 in MLB The Show 26 acts as the final content update for the May cycle, wrapping up the month with some of the most important Red Diamond-tier rewards and collection pieces. For players chasing top-end cards like May Lightning Jacob Misiorowski or the Retro Lightning Fernando Tatis Jr., this drop is basically the missing puzzle piece that ties the whole program together.
At this stage of the program, most players are already deep into the grind, so Drop 5 mainly focuses on completing collections, boosting program progress, and filling in the last required Spotlight cards.
Major Reward Highlights
The Drop 5 update doesn’t just add filler content. It directly impacts two of the biggest May Lightning collections in Diamond Dynasty.
Spotlight Series Cody Bellinger (95+ OVR) is the headline reward on the main program track. You unlock him at 140 program points, making him one of the core mid-to-late progression rewards in the system. He’s also important for progressing toward the broader May collection structure.
May Lightning Jacob Misiorowski is tied directly to collecting May Spotlight players from all drops, including Drop 5. If you missed earlier packs, this drop helps close the gap so you can finally complete the full set.
May Retro Lightning Fernando Tatis Jr. (2021 Retro Finest) is unlocked by collecting 15 total May Spotlight cards. The key detail here is that you do not need the rare Drop 5 pack cards to finish this collection, which makes it more accessible than it first appears.
Experience Choice Pack becomes available at 60 program points. This gives you a choice of four non-sellable 10,000 XP boosts, which is a small but efficient way to speed up parallel progression if you’re still leveling cards.
Program Progress and Free Packs
The entire May Spotlight Program requires 500 total program points to complete. Along the way, players can earn up to seven free packs, which are spread across the reward track and collection milestones.
Packs 1 through 5 are earned naturally through the main progression path by completing Moments, missions, and accumulating program points. These typically appear every 50 points or so, keeping a steady reward rhythm as you play.
Pack 6 is slightly different. It unlocks automatically after you obtain Cody Bellinger and reach 500 Player Experience Points with him. This makes Bellinger not just a reward card but also a progression gate for extra rewards.
Pack 7 is tied to the Retro May collection, meaning it’s only available once you’ve committed to completing the broader May Spotlight set.
Fastest Completion Strategy
If you want to finish the Drop 5 stage efficiently, the key is to avoid over-focusing on Moments and instead let gameplay missions do most of the work.
The most efficient approach is building a synergy-focused squad. Use only Spotlight Series and Topps Now players in your Diamond Dynasty lineup so that every game contributes to multiple objectives at once. This saves a huge amount of time compared to swapping lineups constantly.
For gameplay, Mini Seasons on lower difficulty settings or Play vs CPU are the most reliable methods. These modes let you control pacing, which is important for farming stats without unnecessary stress.
Focus on stacking multiple objectives in the same run. You’ll naturally progress toward things like total PXP milestones, Spotlight PXP requirements, and general hitting or pitching goals.
The key stat targets to keep in mind are:
Total PXP: 10,000 with any players
Spotlight/Topps Now PXP: 2,500
Infield Total Bases: 50
Outfield Hits: 30
Pitcher Innings: 18
Starting Pitcher Strikeouts: 24
If you structure your games properly, most of these will overlap naturally rather than requiring separate grinding sessions.
Drop 5 is less about introducing new complexity and more about completing the system. If you’ve been following the May Spotlight Program steadily, this final drop is what lets you convert partial progress into full collections and unlock the top-tier Lightning rewards.
The biggest takeaway is simple: focus on efficiency, stack missions together, and don’t waste time isolating objectives. Once everything overlaps, the entire 500-point grind becomes much smoother and faster than it looks at first glance.
