MLB The Show 26 Stubs: How to Make the Most Out of Every Purchase
What should I spend Stubs on first?
Most players should spend Stubs on players, not packs.
That sounds obvious, but it’s the most common mistake: buying packs because they feel like the “main” thing Stubs are for. In practice, packs are gambling. Even when the odds look decent, you can burn through 50,000–100,000 Stubs quickly and end up with nothing that improves your lineup.
If you’re trying to improve your team, the best early use of Stubs is:
Filling weak positions with reliable cards from the marketplace
Buying bullpen arms (often cheaper than hitters but make a big difference)
Buying cards needed for collections only when prices are stable
Your first goal should be building a lineup that performs well online and can handle CPU grinding. That means consistent contact hitters, solid pitching, and at least one dependable closer.
Are packs ever worth buying?
Sometimes, but only under specific conditions.
Packs are worth buying when:
You have extra Stubs after your team is already strong
You’re comfortable taking a loss for entertainment
There’s a limited-time pack with a guaranteed tier reward
You’re chasing collection progress and can afford the risk
In most cases, packs are not a “team-building strategy.” They are a lottery ticket. The expected return is usually lower than what you paid.
A lot of experienced players treat packs as something you earn through gameplay, not something you purchase heavily with Stubs.
What is the safest way to improve my team using Stubs?
The safest method is buying mid-range cards that hold value.
High-end cards are tempting, but they can drop fast when new content releases. The best value is usually in cards that:
Are consistently usable (good swing, good pitch mix, good quirks)
Fit meta roles (speedy outfielders, sinker/cutter starters, lefty relievers)
Stay relevant even when better cards come out
For example, a 20k–40k Stub card that stays in your lineup for a month is a better buy than a 150k card that drops to 70k in two weeks.
If you do buy expensive cards, try to buy them when the market is calm and avoid buying right after they spike.
When is the best time to buy players on the market?
The best time is usually when new content drops.
When a new program, pack, or event launches, the market gets flooded. Players open packs, pull cards, and list them quickly. Prices often dip for several hours, sometimes longer.
The worst time to buy is:
Right before a big collection drops
During hype periods when YouTubers highlight a card
When there’s a sudden shortage in supply
If you’re patient, you can often save 10–30% just by waiting for the right window.
Should I invest Stubs to make more Stubs?
Yes, but only if you keep it simple.
Many players overcomplicate investing. They try to predict huge swings and end up stuck holding cards that never rise. A safer approach is flipping and short-term investing.
Flipping means buying cards at buy order price and selling at sell order price. You make profit off the gap.
The key is to flip cards that:
Have steady volume (they sell quickly)
Have a decent spread (profit after tax)
Aren’t too risky (no sudden crashes)
Instead of flipping expensive diamonds, many experienced players flip silvers, golds, or program cards because the market moves faster and you don’t need huge capital.
A good flipping routine is boring, but it works.
What is the biggest mistake players make with Stubs?
The biggest mistake is spending Stubs too early.
Early in the game cycle, you don’t need the best possible card at every position. Content comes fast, and strong free cards are released constantly through programs, ranked rewards, events, and conquest.
A lot of players spend 200k Stubs building a “perfect” lineup in the first few weeks, then realize half those cards are outdated shortly after.
A smarter approach is:
Build a competitive lineup using affordable cards
Grind programs for free upgrades
Save Stubs until you know which collections or players you truly want
The players who stay rich are usually the ones who avoid panic buying.
How do collections affect Stub value?
Collections are where Stubs disappear fast.
Locking cards into collections can be worth it, but only if the reward is something you’ll use long-term. Once you lock a card, you can’t sell it again, so you’re turning Stubs into permanent progress.
Before you lock anything, ask yourself:
Will I actually use the collection reward for a long time?
Am I locking expensive cards that might crash later?
Would I rather keep flexibility for future content?
Some collections are great value. Others are mostly for completionists. The problem is many players lock cards automatically, without checking if the reward improves their team.
Collections should be treated like a long-term plan, not something you rush through.
Is it better to buy Stubs or grind for them?
If you play regularly, grinding is usually enough.
MLB The Show rewards consistent play more than people expect. Conquest maps, Mini Seasons, programs, and ranked/event rewards can generate a steady Stub flow, especially if you sell everything you don’t need.
Buying Stubs makes sense if:
You don’t have much time to grind
You want to compete online immediately
You’re fine paying for convenience
But even if you buy Stubs, you still need to spend them correctly. Plenty of players spend real money, buy packs, and end up with a team no better than someone who played for free.
Some players check the MLB The Show 26 stubs shop and assume the best use is immediately buying packs. In reality, the smarter move is usually using those Stubs on specific players or market opportunities, because that gives you predictable progress.
How can I avoid wasting Stubs on cards that crash in price?
You can’t avoid every crash, but you can reduce the damage.
A few practical rules help:
Don’t buy right before major content updates.
If a big program or season update is coming, expensive cards often drop because players sell off to prepare.
Avoid buying a card at its peak hype.
If everyone is talking about a card, the price is usually inflated.
Buy cards you can actually use.
Even if a card drops, it still has value if it plays well for you.
Sell cards before you stop using them.
Many players keep old cards sitting in inventory, even when they’ve moved on. Selling early is often the difference between staying profitable and losing Stubs.
What should I do if I’m low on Stubs?
If you’re broke in MLB The Show 26, the fastest recovery plan is usually:
Stop buying packs entirely
Sell cards you don’t use (especially duplicates and bench players)
Grind programs that give sellable rewards
Flip low-risk cards for small profit
The mistake low-Stub players make is trying to “hit big” with packs. That usually makes the problem worse.
A better strategy is slow rebuilding. Make 2k–5k profit at a time, repeat it, and let your Stub balance grow naturally.
Once you get back to 50k–100k, you have more freedom to make stronger market moves.
What’s the best way to decide if a player card is worth the Stubs?
Don’t focus only on overall rating.
Some cards play better than their rating because of swing animations, pitch mix, quirks, or how their attributes fit your playstyle. Other high-rated cards feel slow or inconsistent.
Before spending big Stubs, check:
Contact and power vs both sides
Vision and clutch (important online)
Fielding animations and reaction
Pitch mix and pitch speeds (for pitchers)
Stamina and control (for starters)
Also think about how long you’ll use the card. A 90k card that stays in your lineup for weeks is better than a 30k card you replace in two days.
Final advice: How do experienced players stay Stub-efficient?
Experienced players usually follow a simple approach:
They spend Stubs like a business, not like a casino.
They avoid packs unless there’s a clear reason. They buy players when the market is down. They sell cards before prices fall. They grind programs and treat sellable rewards as income.
Most importantly, they don’t chase every new card.
If you want to make the most out of every purchase in MLB The Show 26, focus on predictable upgrades, keep your Stubs flexible, and only lock them into collections when the reward is truly worth it.
