Are you still grinding Bastions and Rocket Troopers in ARC Raiders' Damage Trial but struggling to push past mid-tier scores? Meanwhile, other players are breaking 90,000+ damage with ease-what are they doing differently? The answer isn't better weapons, but better target selection. Plasma Troopers are quietly becoming the most efficient scoring unit in the current meta, and this ARC Raiders Items guide breaks down exactly why.
The New Meta After Rule Changes: Kill Count Matters More Than Targets
With recent developer changes, Bombers no longer count toward trial progress, completely shifting the optimal strategy. The real focus now is maximizing kills per minute rather than chasing tanky targets.
Plasma Troopers stand out because they share spawn logic with Rocket Troopers but have significantly lower HP (around 1,500), making them much faster to eliminate. This turns them into a high-efficiency farming target that fits perfectly into fast rotation routes.
Why Plasma Troopers Are the Best Target Right Now
Plasma Troopers offer three major advantages:
First, they have roughly 40% less health than Bastions, allowing for much faster kill cycles.
Second, they drop useful resources like shields and ammo, reducing downtime between runs.
Third, they spawn in predictable locations alongside Rocket Troopers, making route planning highly efficient.
In short: faster kills, better sustain, and tighter spawn clustering make them the ideal farming target.
Optimal Loadout: Built for Consistency and Mobility
To maximize efficiency, your loadout should focus on sustained damage and mobility:
Use the Cautious Module to increase inventory flexibility and a Green Shield for baseline survivability. The Jupiter weapon serves as your primary ARC clearing tool, while the Anvil helps handle unexpected PvP encounters.
The most important tool is the Wolf Pack Drone, which enables fast Plasma Trooper eliminations. Pair it with a Grapple Hook for vertical positioning, and bring basic stimulants and healing items to maintain nonstop combat flow. Proper resource management here directly impacts your overall scoring ceiling.
Combat Tip: Shield Timing Is Everything
The key to efficiently killing Plasma Troopers lies in their shield phase.
First, weaken them until their shield triggers. Once the shield activates, immediately deploy the Wolf Pack Drone to burst them down. In most cases, this results in a full kill or leaves only 1-2 finishing shots.
Be sure to clear nearby ARC enemies first-otherwise, the drone may prioritize the wrong target and waste your damage window. Good players consistently lose efficiency here without realizing it.
Map Strategy: Blue Gate High Ground Rotation
In the Blue Gate map, focus on three key zones:
Areas around the Bastion zone and warehouse provide consistent natural spawns, typically 1-2 Plasma Troopers per run. High vantage points such as the vehicle repair rooftop and the reception hill offer excellent visibility, allowing you to track spawns without wasting time moving blindly.
The core strategy is simple: hold high ground, scan spawns, and execute quick kills-avoid unnecessary fights or long rotations. Every second saved compounds into significantly higher final trial scores.
Who is this for? What can it do for you?
This method is ideal for:
Competitive players: 34K+ points per match, easily pushing damage over 90K
Casual players: simple execution, no need for top-tier aim
Resource-strapped players: Plasma Troopers drop ammo and shields, fully self-sustaining
Players hit hard by the update: a direct guide to how the new version works-no detours
Its main advantage is simple: less time wasted, more kills secured, and a smoother progression curve that consistently pushes you toward higher damage brackets.
Pro Tips (From Real Runs)
Avoid killing scout units unnecessarily-they can reduce valuable spawn activity.
Always clear nearby ARC mobs before deploying drones to avoid mis-targeting.
Some locations can spawn two Plasma Troopers back-to-back-don't leave too early.
Treat Wolf Pack Drones as high-value resources; every deployment should guarantee a kill.
If competition is high, rotate zones or switch maps instead of cheap ARC Raiders Items forcing fights.
