99 Nights in the Forest Item Guide: Bandages and Healing Tips
In 99 Nights in the Forest, survival is not just about fighting enemies or surviving the night—it’s about managing your health in a world where healing resources are intentionally scarce. Among all survival items, Bandages stand out as one of the most important tools you can find or craft.
Because passive healing is limited and danger ramps up quickly in later nights, understanding how Bandages work—and how to consistently obtain them—can make the difference between a clean escape and a full team wipe.
What Bandages Do
Bandages are one of the core healing items in the game. They serve two essential functions:
Restore a large portion of your health (around half of your HP bar)
Revive fallen teammates in multiplayer
This dual purpose makes them extremely valuable. Many players underestimate their importance early on and end up running out right when they need them most.
Unlike food-based healing or minor regen effects, Bandages are immediate and reliable, which is why they are often reserved for emergencies.
How to Get Bandages
Bandages are not common, and you won’t always find them in predictable places. There are three main ways to obtain them.
1. Exploring the Map and Looting
The most straightforward way to find Bandages is through exploration.
Clinics and hospital-like buildings are the best source
These structures often contain medical loot such as Bandages, Medkits, and occasionally high-value healing food
They typically appear once your campfire reaches mid-game levels
However, they are dangerous zones, often patrolled by strong enemies like Alpha Wolves
Loot chests in various structures
Cabins, wrecked planes, and random survival points can contain healing items
Drop rates are inconsistent, so this method is unreliable but still worth checking
Exploration remains the backbone of Bandage farming, especially in early and mid-game progression.
2. Crafting at the Anvil
Crafting becomes the most consistent way to secure Bandages once you progress far enough.
To craft Bandages:
Locate the Anvil structure near the Cultist Stronghold
Break through the gate using a strong tool such as an upgraded axe or chainsaw
Clear the enemies inside before attempting to use the area safely
Repair the anvil by collecting scattered shards within the building
Once repaired, you can craft Bandages using basic hunting materials:
2x Rabbit Feet
2x Wolf Pelts
Drop the materials directly onto the anvil to produce Bandages.
This method is extremely reliable in mid-to-late game if you maintain steady hunting routes.
3. Choosing the Medic Class
If you want guaranteed early-game survivability, the Medic class is one of the strongest starting options.
Benefits include:
Start each run with 2 Bandages automatically
Upgrading the class increases your starting supplies further
At higher levels, you may also receive a Medkit at the start
This class reduces early pressure significantly and allows safer exploration before you establish a crafting loop.
Healing Strategy and Survival Tips
Knowing how to use Bandages is just as important as knowing how to obtain them.
Save Bandages for Revives
In multiplayer, Bandages should usually be reserved for reviving teammates.
Using them for minor self-healing is inefficient when food or safer recovery options exist. A dead teammate represents a larger loss than a partially damaged player.
Bandages vs Medkits
Medkits provide full health restoration, making them more powerful than Bandages for self-survival.
However, both items can revive teammates.
The key rule:
Never use a Medkit for revival if a Bandage is available
Save Medkits for emergencies or full healing situations
Efficient item management becomes critical during long survival runs.
Food-Based Healing Strategy
Some classes, especially the Chef, can drastically reduce reliance on Bandages.
Food healing items such as:
Cake (large health recovery)
Jelly jars (full heal plus buffs)
allow you to preserve Bandages for combat emergencies instead of recovery between fights.
This creates a sustainable healing loop where consumables handle routine damage while Bandages are saved for critical moments.
Special Event Healing Use
Some in-game events require precise healing management. For example:
Injured wildlife encounters may require multiple Bandages to complete a quest
Failure to use the correct amount can waste valuable supplies
Always pay attention to event requirements before spending healing items.
Dungeon and Stronghold Preparation
Before entering high-risk zones such as:
Cultist Strongholds
Alien structures
Frozen or late-game temples
you should always stockpile healing items.
A common mistake is underestimating damage spikes in these areas. Once inside, recovery options are limited, and Bandages become your primary safety net.
Bandages are one of the most important survival resources in 99 Nights in the Forest. While they may seem simple at first, their value scales heavily into the late game where mistakes are punished harshly.
Players who learn how to:
Farm them efficiently
Craft them reliably
And manage them strategically
will consistently outlast those who rely only on random loot.
Survival is not just about fighting harder—it’s about healing smarter.
