MMOexp:MLB The Show 26 Guide:Turn Double Plays Into an Advantage and Control Every Inning
Have you ever experienced this frustrating moment in a game? You're finally ready to break the inning open with a big hit, but instead you ground into a double play and erase everything. Or on defense, you're right in front of the ball but a slow throw only gets one out instead of two. You might be wondering:why can other players handle double plays so smoothly while you keep giving away innings in key moments? Is it really just execution, or are you missing the rhythm of these situations? If this sounds familiar, this guide will help you turn double plays from a MLB The Show 26 Stubs disaster into an advantage.
WHY DOUBLE PLAYS DECIDE CLOSE GAMES
In MLB 26 Stubs for sale, double plays often become the turning point of close matches.
A well-executed double play can instantly kill the opponent's momentum, while hitting into one can completely destroy your scoring opportunity. In tight games, these small details matter more than home runs. Many losses come not from overall skill gaps, but from poor handling of these critical situations.
OFFENSE HOW TO AVOID DOUBLE PLAYS
On offense, avoiding double plays is all about eliminating weak contact.
First, manage your PCI starting position. Placing it slightly lower in the strike zone helps you handle low pitches more consistently, but the goal is not to force grounders-it is to avoid hitting the ball into the ground too softly. Many double plays come directly from poor low-contact swings.
Second, improve your pitch selection. With a runner on first, prioritize pitches in the upper-middle zone. These are more likely to result in fly balls or hard contact to the outfield, reducing double play risk at the source. Do not swing at everything-taking pitches is often the safer choice.
With two strikes, consider using contact swing to increase forgiveness and keep the ball in play. The goal is not power, but survival of the at-bat and avoiding weak grounders.
DEFENSE HOW TO TURN DOUBLE PLAYS
On defense, completing double plays depends on reaction speed and throwing quality.
Player fielding attributes matter a lot. Higher fielding ratings improve reaction time and animation speed, especially for second basemen and shortstops. Strong infielders turn routine grounders into reliable double play opportunities.
Throw timing is equally important. In clutch situations, using a stable blue meter throw helps reduce errors and speeds up transitions between outs. Many failed double plays are caused not by the catch, but by slow or inaccurate throws.
You must also track base runners. Preventing stolen bases or extra advances is crucial to keeping double play opportunities intact, especially in high-level competition.
GAME SENSE AND RUNNER CONTROL
Double plays are not just mechanics-they are decision-making situations.
When the pitcher is ahead in the count, hitters are more likely to attack strikes, which changes your defensive expectations. When behind in the count, hitters tend to be more selective, increasing the chance of weak contact or walks. Understanding count pressure helps you anticipate outcomes.
You can also use pickoff attempts to control the runner on first base. A successful pickoff can completely remove the double play threat and reset the inning in your favor.
READING YOUR OPPONENT MATTERS
Different pitching styles require different adjustments.
Against sinker-heavy pitchers, adjust your PCI lower. Against fastball-focused pitchers, prioritize upper-zone coverage. Anticipating pitch patterns before the ball is thrown is what separates average players from advanced ones.
SUMMARY
This guide is for players who frequently ground into double plays or struggle to consistently turn them on defense. By understanding PCI positioning, pitch selection, defensive attributes, and throwing timing, you can significantly reduce mistakes and gain better control over key game situations, especially under pressure.
TIPS
Avoid forcing low pitches with runners on first
Prioritize high-quality contact instead of swinging at everything
Upgrade infield defense, especially second base and shortstop
Use stable throwing timing in clutch situations
Pay attention to pitch count and adjust aggression
Use pickoff attempts to disrupt runner timing
CORE BENEFITS FOR DIFFERENT PLAYERS
New players:Understand double play mechanics and reduce basic offensive mistakes
Advanced players:Improve situational awareness and defensive efficiency
Ranked players:Optimize clutch situations and stabilize win rate control
Competitive players:Enhance execution and perform consistently under high pressure
